Render without background
Sorry if this is asked a lot. So far I've tried setting the Environment Type to None and disabling Visible in Render but my Basic OpenGL still renders still has the default gray background.  I am not too familiar with v4.9 and I forgot how I did it before in earlier versions.  Can someone help me out?
  • Richard HaseltineRichard Haseltine Posts: 112,076
    Do both renders (using simple materials so the 3Delight render is fast) and then use the layer mask from the 3Delight render to separate the OpenGL render. Though I think you will still get fringing.
  • Thanks for the suggestion!  I also tried giving the background a green color so that I can key it out later in after effects but double render / layer mask resulted a bit better in quality.  Really wish I could just simply render a OpenGL with tranparency without the extra work though.
