GOZ and scale
karlakimor
Exporting obj and other formats is possible to set the scale, but with GOZ not. I normally work in Zbrush in the same scale than DAZ, that is convinient for other programs as MAX or MD but when using GOZ it appears huge in DAZ or tiny in Zbrush, I guess 100 times. Is there any way to change this? I don't want to change the scale of the characters in Zbrush as other things can be affected that now work perfectly.
The other option, using OBJ, is a lot more cumbersome, but using OBJ and importing-exporting using the DAZ 1 unit=1 cm then I get the correct size.
