Parenting causes items to move
 Whenever I try to parent or unparent one figure/object to another. The first figure/parent moves from the spot I placed it at. Is there any way to parent/unparent a figure/object from another figure/object without it moving?
  • L'AdairL'Adair Posts: 9,479
    edited May 2016
    When you right-click on a figure/object and select "change parent" from the menu, a pop-up window opens allowing you to select where to parent the select item, or to select none. At the bottom of the window above the buttons is a check box to "parent in place." When this option is selected the item will be parented without moving. If it is not selected, changing/selecting a parent can move the item.
    This option works regardless of whether or not you use the window to change or select a parent.
    While it may be easier to drag a weapon and drop it onto the character's hand, especially if you have a lot of items in your scene, it's a good idea to do the right-click thing and make sure the option is checked first.
    (Be kind, I'm doing this all from memory as DS is tied up at the moment...) laugh
    Post edited by L'Adair on
  • Thanks so much. That was bugging me for the longest time.
    It drove me nuts, too, until I figured it out. lol
  • Cris PalominoCris Palomino Posts: 12,959
    Good info, L'Adair, thanks.
