Men of character for Michael 4 not loading
Hi there,
I bought this product, Men of character for Michael 4 (http://www.daz3d.com/men-of-character).
It seems to be correctly installed and I can see all the faces, but when I select Michael 4 and click on the faces, they won't load.
Any help would be much appreciated.
Thank you.
_KN
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Poser or Daz Studio? Did you isntall to the same content directory as the base Michael 4?
  • Cris PalominoCris Palomino Posts: 12,964
    Hi, these are the instructions for installation:
    To properly install and use your Men of Character morphs, you must update the ExP for M4.
    1. The product must be installed in the same runtime as your M4.
    2. Once you install the product, run the updater. On PC, this is done with the DzCreateExPFiles-M4.bat, or on Mac with DzCreateExPFiles-M4.command.
    3. Double click the appropriate file for your OS and this should update the ExP (\Runtime\libraries\!DAZ).
    4. Open your program and load your M4 (this should be a fresh Michael 4 base for best results).
    5. Select the head.
    6. From your Pose library, load the INJ Men-of-Character (the INJECT ALL is highly recommended).
    7. In your head parameters, you will find a group of morphs named MOC-morphs (Men of Character morphs).
    If you have installed, Hiro 4, it is basically the same setup.
  • KNKN Posts: 55
    Thanks, guys!  I managed to make it work,  Have a great week!  :-)
