aniMate2 and 4.9
I purchased aniMate2 way back when. Does 4.9 still support this?  All I get is aniMate light on my tool bar. I tryed reinstalling aniMate2 from web site but it says it cant find the path that )))--->IS<---((( there........aniMate 2 also does not appear in my install manager.  Help.
  • jaebeajaebea Posts: 456
    My Animate2 has been coming with each version, including the newest Beta.  It installs no problem.  I have been using it like crazy!
  • Well mine has not.
  • fixmypcmikefixmypcmike Posts: 19,710
    How are your Download Filters set in Daz Install Manager?
  • All turned on except for mac
    Does DIM show Animate 2 as installed, or not show it at all?
  • Arnold CArnold C Posts: 740
    edited May 2016
    A most recent aniMate 2 plugin DLL is part of the default DAZ Studio installation since DAZ Studio 3. There is no need to install a seperate version. All what aniMate 2 needs to work is the serial key. When it only shows aniMate Light, check under "Help", "About Installed Plugins..." if it is registered properly. You should see an input field for the serial key under the "aniMate 2" entry and "Registration". If there isn't one and it shows the "Light" version only, something might have corrupted its registry entry on your OS. In that case I'd contact the Help Center for if and how to re-register an already registered plugin.
    Post edited by Arnold C on
  • Do animate2 work whis the mac version?
  • Just resolved my issue of no animate2 by doing this
    To activate aniMate2 in DAZ Studio 4, go to the "Help" menu and select "About Installed Plugins". Next, find the entry for aniMate2 and click to select, then type or paste in your serial code into the Serial Number field. Finally, click on the "Accept" button to finish registration. The aniMate2 serial code will be listed in your "Serial Numbers" section of your www.daz3d.com account after you order this product.
