blank screen when rendered
Hi i wonder if someone could help me ,sometimes when i render i just get a blank png transparant render, it renders, closes itself and there is nothing there, this is happening more often and i cant use my iray.I am using 4.8 iray windows 8.1.The 3delight works fine .Any clues anyone ?
  • LinwellyLinwelly Posts: 6,065
    Did you change the shaders to Iray? Did you look at the log files? Maybe that gives a clue as to what happened.
  • KnittingmommyKnittingmommy Posts: 8,191
    Usually, when I have a black screen in Iray, I have forgotten to:
    1. Use Iray lights or turn on Photometric if I'm going from 3Delight (yeah, I know, I'm not in there often) in the lights tab with the light selected
    2. use the correct Dome/Scene/whatever setting and I'm only using a distant light, but accidentally forgotten to delete a 3Delight skydome if it came with a set.
    There was one other situation when this has happened, but I've forgotten what type of situation that is as it hasn't happened in awhile.
  • scorpioscorpio Posts: 8,533
    I've been gettting this with one scene I've set up. It rendered fine then I did something and now can't get it to render anything but the blank screen, other scenes are fine just this one, and sorry I haven't figureed out what the problem is. When I've had this happen before I've just had to alter the camera angle slightly and the image rendered fine but thats not working this time.
    Check the lighting and environment settings (in the Render Settings).
  • SPACECHIMPSPACECHIMP Posts: 212
    Hi thanks everyone for your help I will go through and check all this and let you know -I think it might be something to do with camera angle as Scorpio says, Thanks for all your help!
