Problem with "Jemima for Victoria 4 and Genesis"
Hi,
I noticed a problem with the above product's materials when I rendered her face and head.  Using the default render settings for 3Delight, I get the following result (see image below).
She comes out like this when I load her using either the default actor (.duf) file, or if I load in Genesis and apply the Jemima shape and base material.   Has anyone else had this problem?
How do I fix it?  (I've already tried un-installing and re-installing the product)
400 x 400 - 140K
  • Richard HaseltineRichard Haseltine Posts: 111,367
    It appears to have both Poser and DS materials - it may be that the face is using one and the rest of the body the other. Do you get the same issue with the make-up prsets? If not and there's a reset/no make-up option that may be a work-around though this does look like a bug (assuming you are using the native Daz Studio materials).
  • Stretch65Stretch65 Posts: 176
    The makeups only change the eye mascara and lip colour.  There's no reset/no make-up option for her.  Do I contact DAZ for support on this, or the author?
    Daz please - select Techncial Support as the contact department.
