3Delight Problem
hermun81hermun81 Posts: 101
All of a sudden DAZ has started running very sluggishly, and I get this error message every time I try to render.
3Delight message #45 (Severity 2): S2069: the interface of shader 'C:/Users/user/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Surface.sdl' is invalid
The characters skin (all characters) renders as white, no colour or features.  This used to happen from time to time, and reloading the file would fix it, but not any more.
Has the save file been corrupted?  Or is my computer dying or what?
  • Richard HaseltineRichard Haseltine Posts: 111,430
    The shader file generated from a Shader Mixer shader - possibly the Age of Armour SSS Shader - is corrupt. If you go to the C:/Users/user/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/ folder and delete its contents then try to render again that should work. That doesn't however explain any sluggishness. Have you revently changed your security software, or updated your video drivers?
  • SF-DesignSF-Design Posts: 987
    As Richard said deleting that "brickyard" folder solved the problem here all the time.
  • hermun81hermun81 Posts: 101
    It's already empty.
    Delete the contents after you get the error, then try rendering again.
