Simple rotation and translation question
I LOVE that Carrara is openly extensible and the samples and cookbook are helpful.
However, I really would like a sample code of how to
1. change an object's x,y,z translation
2. rotate the object
3. set a keyframe
I have achieved setting a keyframe. But every time I try to rotate an object the scale changes also.
I use the I3dShTreeElement:
TMCCountedPtr object; I set the time using:
MicroTick inTime=180000;
scene->SetTime(inTime,true,false,false,false);Thanks to Carrara's auto keyframing, any changes set will create a keyframe at the above time.
But I can't transform an object accurately. So can someone give me an example that is the best practice
that is equivalent to the following:
object.xPosition+=10;
object.yPosition+=10;
object.zPosition+=10;
object.xRotation=45 degrees;
object.yRotation=45 degrees;
object.zRotation=45 degrees;I appreciate any help greatly.
If you don't want to handle matrixes, then look at SetPhyThetaPsy() or Euler angles. But Matrixes are more flexible, and are easier to do things like point at another object.
