Required products missing - shirt styles for David's clothing Pack
So I decided to go and start adding some icons for those missing in my product library and at the top of the list is
http://www.daz3d.com/18-shirt-styles-for-david-s-clothingpack
but in order to create a scene to render the image I need to load the shirt first. I looked under "D" for David's clothing pack" but it's not there, so I decided to check out the product page to see what the actual pack name was and if I had it, but the Required Products entry is missing from that page :(
  • Richard HaseltineRichard Haseltine Posts: 111,382
    I suspect the pack is nio longer available, in whichc ase you would need to opena support ticket to ask fora  refund if you cannot purchase the base set.
  • kaotkblisskaotkbliss Posts: 2,918
    It was a freebie so no refunds LOL
    kinda stinks I can't use it though. Doesn't make sense that they'd remove the required product, but leave the add-on unless the shirt styles are already removed but I can still see the product page because I have it...
    Still worth opening a support ticket, they may be able to make the base David Clothing Pack available to you.
    Couldn't hurt :) I'll give it a try
    Thanks
