Tatoos: Genesis art on G2* characters thru Geo Shells?
ScavengerScavenger Posts: 2,677
I'm wondering if something like this http://www.daz3d.com/hawaiian-tatau could be used with Genesis 2 (or 3) by using geometry shells with the proper UV applied to it...can the uv be applied to it?
    A geometry shell is just a specialized duplicate of the mesh it is created from and therefore can only have the same UV mapping the original mesh can have.
  • Richard HaseltineRichard Haseltine Posts: 111,390
    No, a Geometry Shell (unlike an Instance) can have different UVs.
    I meant they only have the UV options that the original mesh has so a geoshell is no help at applying for example a Victoria 3 UV to a Genesis figure.
    Right, it has the same list of UVs - because it's the same mesh - but it isn't limited to using the same one as the base geometry.
