FabTex IRay shaders
marblemarble Posts: 7,500
edited May 2016 in The Commons
http://www.daz3d.com/fabtex-pattern-iray-shaders-camellia
I bought the above texture shaders and in going through the various options I have hit a problem with the "Sheer" shaders. Please see the attached screen shot. I'm wondering whether there is a prerequisite although the product page does not say so.
Also - I can't find any way to remove or zero the shaders. They seem to load one on top of the other. This means I'm deleting the clothing and reloading it when I change a shader.
652 x 436 - 37K
Post edited by marble on
  • WilmapWilmap Posts: 2,917
    I've jsut checked mine and found the same problems. Think you need to put in a ticket.
  • marblemarble Posts: 7,500
    Thanks - Just logged a suppport ticket.
  • Richard HaseltineRichard Haseltine Posts: 111,332
    edited May 2016
    Looks like it's trying to set the UV Set, which it shouldn't be doing. However that shouldn't in itself stop the effect from working once the error is cleared.
    I think you are right, Richard. Something is applied but the error was concerning. A bigger problem is the fact that I can't remove a shader once applied. Also, tiling doesn't look right (stretching more in the horizontal than the vertical) and tiling doesn't include bump/normal maps so (according to the PDF) there is manual editing required to match pattern and normal map. All in all, I'm thinking of returning it (sorry Diane).
