Transparent items not transparent
Ever since I moved to Carrara 8.5 from 7.2 it's like there's some new, dumb issue everyday. For some reason an item that is transparent in the actual main view, renders out as visible. It has no alpha value. It's clearly transparent in the main view. Thanks
Screen shots could help!
Render settings could be playing a role. For instance if you enable Skylight and/or Indirect Light, there is another Light Through Transparency option to enable in addition to the one in the options for the standard renderer at the top of the tab.
It is also possible that there are settings in the shader tree that are causing issues. Hard to say without more information and/or screen shots.
