4 independently riged hydraulics work in unison ?
RorrKonnRorrKonn Posts: 509
Can D/S have the 4 RED HYDRAULICS move the GREEN plate up n down on all four corners n have all 4 of the TED HYDRAULICS work independently but do correctly ?
Thanks a lot
you can see .jpg here
http://blenderartists.org/forum/showthread.php?398372-4-independently-riged-hydraulics-work-in-unison&p=3046353#post3046353
and how do we post a .jpg here with out a url ? the direction are not in english
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Split each ram into two bones, one of each the child of the a child of the blue bisc and the other of the green. Make sure their y-axes run precisely along the centre of the cylinder, with the centre point at the pivot. Now make each pair or fams point at each other. The rams won't drive the disc, that will have to be rigged as a standard bone, but they will remain correctly aligned.
    T embed an image in a post click the Image button in the toolbar and enter the URL, then set the width to 800 if it is greater than 800 - though in this case since the image is hosted on another forum you should link to the post, not to the image itself.
