Measure Metrics
Hello,
I have Measure Metrics, and am having a hard time trying to measure a prop. I've followed the directions, and no matter what option I select, the tape measure starts it's measurements from the center of the prop (I assume where the origin point is). How can I get it to start measurements from where I want, rather than the center?
Thanks
  • Richard HaseltineRichard Haseltine Posts: 111,922
    Create a new Measure Metric Tape measure - Default Settings option and Create persistent Point at Target. Select the thing you wish to measure, then the Tape Measure and use the Align pane to line it up with one side. Select teh Point at target, set its scale to 0%, then deselect; select teh thing you wish to measure, then the pojnt at target, and use the Laing pane to line the target up with the other side. You should now be able to read off the desired size.
