Aux Viewport Pane resize
marblemarble Posts: 7,500
edited April 2016 in Daz Studio Discussion
I undocked my Aux Viewport and when I put it back it now takes up the whole Left Hand panel. Originally it ws a small window at the top of that LH panel. There does not appear to be any drag handles or borders that can move. Can anyone remind me how this is done - I'm sure I used to be able to do this. I'm on DS 4.9 Windows version (it does the same on my Mac).
802 x 385 - 65K
Post edited by marble on
  • Richard HaseltineRichard Haseltine Posts: 111,688
    I don't think it should be doing that - please open a support ticket with the .dsx files attached from the folder with the log in it (for Windows C:\Users\YOU\AppData\Roaming\DAZ 3D\Studio4 - AppData is a hidden folder so you need to enable the display of hidden files and folders in the Windows 8+ tab bar or the Windows 7 Control panel Folder Options applet, I'm not sure where the Mac settings are - ~/Application Support rings a bell). If you undock the Aux Viewport and size it small before redocking does that help? If not reload your layout from Window>Workspace>Select Layout.
  • marblemarble Posts: 7,500
    I'm wondering if anyone else is having this problem. I noticed it on the Mac and now on the Windows 10 PC which is a new install.
    By the way - I posted a screen shot - any reason it has been removed?
  • fixmypcmikefixmypcmike Posts: 19,729
    I'm seeing it.
    Oh - it's back (the screen shot). Odd.
    edited May 2016
    Loading a new Layout is, so far, the olny way I've found to get the small window back. By the way, this is not only an issue for the Aux Viewport - none of the tabbed panes can be resized. I'm not sure about other styles - I only use City Limits.
