Daz 4.9 issues
Hello Everyone, I was curious about something. Has anyone had any issues of lines showing up when you place the XYZ arrow on any of your models? I'm asking this because, I've had this happen to me. When I got the update, everything seemed fine. Then when I recently loaded a new content model from the DAZ Connect site, my issues started from there. I was making an attempt at moving my content model in the scene.When I did this, some lines started showing up in the area. If I touched on one arrow, say the red one, I would get a long line of spaced out red markers, indicating the length of my direction. Also I've recently been having issues with my Win 10 toolbar, to which I thought it was a problem of the Win 10 OS. After contacting the Microsoft Tech Support, I was told that one of my apps was causing issues with the program systems. (The effected areas were Startup, Wi-Fi and the Information sidebar). After it was fixed, I went on to work with my Daz program again. When used it last night problem returned again. After I did my own troubleshooting, I come to realize that my issue was not with any other apps, but was with the Daz 4.9 program. (This was found out after I uninstalled it from my computer and everything returned to normal) I sent a ticket to the local site tech here the time it happened (5 days back now) and I'm still waiting for a response. Again, has anyone else had this happen to them? Any answer will be helpful and appreciated
I have two screen shots of my problem.
1920 x 1080 - 216K
1920 x 1080 - 481K
  • Richard HaseltineRichard Haseltine Posts: 111,929
    I think you have Guides checked in the Tool Settings pane, though what you see isn't the same as I am getting. It may also be worth checking your video drivers are up to date.
    What task bar issues are you having?
