I need help with michael 3 clothes not aligning correctly!
I'm trying to fit wild west cowboy clothes to M3 but the shirt is not fitting inside the jeans and also the jeans are overlapping with the boots. Here is a pic to give you a better idea:
Also some pieces of clothes are not morphing along with the figure. Can somebody help me please? Thanks in advance!
Post edited by Chohole on
  • LeanaLeana Posts: 13,504
    The jeans probably have a morph to fit them inside the boots.
    How can I make sure? Where do I find it?Is not in the "parameters" menu!
    With the denims selected (the whole figure, not just part of it) there's a "PBM-Bootleg" morph to fit inside the boots -- if you aren't seeing it, click on All on the left of the Parameters pane.  The morph for the shirt is called "PBM-TuckedIn".
  • Oh, OK I found a morph to shrink the jeans inside the boots, but when I shrink them I can see M3 legs. It looks that it needs some tweaking! I also found a morph for the shirt but it shrinks in the wrong axis and also need some tweaking!
    Here is a pic:
    For the pants legs, the simplest solution is to hide Mchael's legs, since they won't show anyway.  On the shirt, is that the TuckedIn morph?
  • For the pants legs, the simplest solution is to hide Mchael's legs, since they won't show anyway.  On the shirt, is that the TuckedIn morph?
    Exactly, " TuckedIn"  morph! I wasn't aware that I can hide parts of the jeans so that's another solution, hide the parts of the jeans that overlap!
  • Crap, that area can't be hidden! I'll need to hide the legs!
  • edited April 2016
    I can hide the legs, but the jeans look too thin!
    Post edited by l_riefkohl_ferrer_1923365ed0 on
    Are you hiding Michael's legs using the eye icon on the Scene pane?  If you shrink the legs the pants legs will shrink along with them.
    The TuckedIn morph seems to work correctly for me, are you sure you had the shirt selected?
  • Are you hiding Michael's legs using the eye icon on the Scene pane?  If you shrink the legs the pants legs will shrink along with them.
    Yes, I'm hiding the legs with the eye icon. How can I shrink the legs? Clothes are not morphing with M3!
    Which morphs are you using?  Do the clothes show themselves "Fit to" Michael?
  • edited April 2016
    I'm using sexy men morphs, but the problem shows even with no morph injected ...
    ... and yesthe clothes show themselves fit to michael!
    The clothes aren't following even the standard body morphs?
  • They work with the basic stretch arms, legs and neck but not with muscles or tone. Is the "PBM-TuckedIn" morph supposed to go in and out or up and down? I decided to morph the jeans to go outside the boots and not inside and it looks OK.
