Gore-Dom Users?
DDCreateDDCreate Posts: 1,418
https://www.daz3d.com/gore-dom-for-daz-studio
Does anyone know if this product would be suitable on G3 character and in Iray Renders?
  • BeeMKayBeeMKay Posts: 7,019
    You can use them, but you will have to adapt the surface settings for Iray. Also, you will have visible seams (not just in G3, but in any product you use it on), as it applies per surface.
  • DDCreateDDCreate Posts: 1,418
    Thanks Bee! When you say adapt them...in what way?
  • TottallouTottallou Posts: 555
    edited April 2016
    The shaders you noted are 3 Delight so will need to be converted to Iray some convert well just using the standard uber iray but I don't have these to check -
    I am not sure what look you want but you might be able to get it using these
    https://www.daz3d.com/fsl-filthy-dirty-future-iray-shaders
    I was just clicking butons the other day & one of the shaders in this pack gives a "blood" look - I attach a test render I saved so you can see - Its just a test on the Skin & Axe so it could easily be done way better if it was for a real project but maybe it will give you an idea.
    800 x 751 - 111K
    Post edited by Tottallou on
    edited April 2016
    This are LIE-overlays, and not really shaders.
    I made an example for you. This is LEO 7, using Iray surface.
    In this image, I have applied the two Gore-LIE-Layers to the Torso and Arm surface. The application will take some time, and it might look like your PC has crashed, but be patient. You can see the applied layer in the Base Color.
    The third image is the spot-render of the default-application of the layer. The red is pretty bright, as it was concepted for use in 3Delight. Depending on what you are intending to do, you will need to dampen down the color, etc. You can also clearly see the seams at the arms.
    1132 x 571 - 91K
    1117 x 610 - 104K
    1435 x 731 - 126K
    Post edited by BeeMKay on
    Wow did he have a bad day! Thanks for taking the time Bee!
