Applying Rigging To Edited Figure/Obj
I've created an OBJ of the right hand of Genesis for a personal project {also the face, arms/hands & hip/legs - a total of 4 OBJ's}. I've been through a few tutorials on Rigging and using the Transfer Tool but nothing seems to allow me to apply the Genesis rigging to those OBJ's - even after I've turned the Hand into a "Figure".
Here is an image of the Hand:
I'd like it to have the same movements/morphs as it would if it was still attached to Genesis {and the other 3 OBJ's for their respective movements/morphs}.
Is there any way to accomplish this? I don't have any experience with rigging and have only be playing around with 3d modelling up to now. Any help would be appreciated!
Thanks in advance,
M. Stohler
{BlueDragonFire}
  • Richard HaseltineRichard Haseltine Posts: 111,390
    In order to use the Transfer Utility the hand would need to line up with the original Genesis hand.
  • mmsj666mmsj666 Posts: 29
    I'm having issues with rigging OBJs that I've imported into dad and edited them in dad and plan on keeping them in dad. I do the photo metrics I think it's called then the triad weight thing. Then my model disappears(which always scares me) then when I find it it's on it's side and out of scale I think. There's more. After I sometimes have parts attached by a long tethered line or a bumper will be way off. Also the thing disappears and moves a significant distance when I click on it to move it which makes it hard to position cuz when I let go it snaps to it's second would've been position. Also I can't select it by clicking cf on it. I have to use the parameters tab only. These models are becoming more work than they're worth. The only reason I keep them cuz I'm real proud of the finish on the surfaces. Any tips on this.
    It sounds like it may be display optimization issues.  Are your graphics drivers up to date?  In DS, go to Edit > Preferences > Interface and try changing the setting for "Display Optimization" and see if that makes things less erratic.
  • In order to use the Transfer Utility the hand would need to line up with the original Genesis hand.
    Thanks! It didn't work the way I had hoped though I may have expected too much out of doing this. Or I could have done something wrong {missed a step or didn't do one right} but I was hoping to be able to use the morphs {though at least the Hand Poses are working so that's okay}. It also affects the skin when applied {using "James for M5" in this case} and needs to be adjusted. The pics below show what I did and the result {starting from scratch}:
    Here's the result of applying the skin:
    And this shows what I'm trying to get. For this I simply used the whole Genesis figure {x4} and turned the Opacity to 0 on each for the parts I didn't want showing up...
    Yeah, kinda creepy, I know {LOL}. It's a bit of a joke I'm doing of the owner/creator of a game/forum I'm on and I intend on using this character occasionally for goofy scenes. It works okay as it is {with a few adjustments where necessary} but I was really hoping to create a whole character without all the excess. The morphs weren't really important for the Hand-Body but would have been nice if I could get them to work on the Head, Legs and small Arms/Hands when each are seperate from the Genesis figure. Then to combine the 4 parts into one character.
    Anyway, thanks for your help!
    I'll keep checking back here in case you {or anyone else} has an idea of getting the results I'm hoping for.
    M. Stohler
    {BlueDragonFire}
    You can't load the morph as you have changed the mesh (by chopping off the rest of it) - if you were careful to delete exactly the same polygons from a morphed version of Genesis that might work. However, I'm not sure why morphs aren't transferring anyway.
