problems with 4.9 problems with genesis 1, 2 and 3 morphs
I don't know if I am the only one but I had computer trouble which was not that big of a deal and I had to reinstall my OS, and then the problem began. I had to reinstall Daz studios this of course erased all of my directories, that was fine I started reinstalling my content as well, and things were going fine for a while. Then I got to my genesis 2 figures started putting them back in and tried loading one the genesis 2 base loads fine I don't get those F#*@ up blocks like if the starter essentials arent installed, but I tried and loading a morph and nothing this also affected the gen 1 and 3's as well the base will load and none of the morphs.  If i try and load victoria 5, this is just as an example, I get the base and the texture but no morphs. does any one have any ideas why I would work for a while and then the morphs stop loading all across the board.?
  • fixmypcmikefixmypcmike Posts: 19,734
    How are you installing them, and what is the full install path?
  • some were installers and a good deal of stuff from rendersoity and runtimeDNA most installer the more i read on 4.9 it is beginning to paint a clearer picture
  • You might need to clear your morph cache.
    Go into Edit/Preferences in the General tab. There is a textbox at the bottom under "DSON cache files". Click the "Clear" button.
