Need help, file structure confusion for genX2.
Hi Everyone,
I was messing around with genx2 and I transfered my morphs succesfully but a sub category that I dont want was also created. What I see in the shaping menu is Actor > GenerationX > Genesis > Universal > Fantasy Shapes > Morph. Id like to rename and move some of these morphs folders but if I look in the GenX data folder I dont find anything other than the transfered morphs, no folders at all. Does that mean that the sub category is written into one of the morphs? Can I edit this?
Thanks
    edited April 2016
    Not one...each and every one has 'where it belongs' written into it.
    If you open up one of the morphs you should see something like this...near the top, but not too close to the top...starting somewhere around line 26 or so...
    			"channel" : {				"id" : "value",				"type" : "float",				"name" : "Value",				"label" : "Colleen",				"auto_follow" : true,				"value" : 0,				"min" : 0,				"max" : 1,				"clamped" : true,				"display_as_percent" : true,				"step_size" : 0.01			},			"region" : "Actor",			"group" : "/People/Real World",			"formulas" :
    You can manually edit the file or you can edit them by clicking on the gear icon and editing Parameter Settings > Path.  (resave after editing...)
    Post edited by mjc1016 on
    Excellent. Thanks mjc1016.
    Is it possible to customize the morph channels at all? For example, Actor > Full Body > Folder Full of Morphs or something? Also, how did you view the code? The perameter settings > path fix was easy enough, but id like to see the code as well.
  • If you didn't change it, the default is to compress the file, so you would have to use a program like 7-zip to decompress it, then open it in a text editor like Notepad++ for modification. As for creating a new location, when you save it, you should have a option to pick what category iy goes into; you can add new categories at that time.
    Thanks daywalker. Ill give it a try.
