Genesis 3 Morphs Not Appearing in Daz
So I finally got around to purchasing all of the body and head morphs for Genesis 3 Male and Female, along with their Growing Up morphs. However, I've run into an issue.
I downloaded and installed them through the Install Manager like normal and it didn't seem like there were any issues. But when I go into Daz the Body and Head Morphs don't appear in the shaping section, just the basic free morphs do. And every time I try to use the Growing Up morph buttons (which do appear) They don't do anything to change the figure!
Has anyone had this problem happen before, and know how to fix it?
  • fixmypcmikefixmypcmike Posts: 19,742
    Are you looking for them in Smart Content/Content Library, or in the Parameters/Shaping pane?  The head and body morphs won't show up in the library, only as dials in the Parameters or Shaping pane.
  • sjaammonssjaammons Posts: 185
    I know that. What I'm saying is that they're not showing up in either parameters or the shaping plane, the tag below "smart content." The only things that show up are the bare bones free morphs that come with the figures at the start. the Genesis 3 Head and Body Morph dials will not appear like the Gen 2 ones I bought will. I downloaded and installed them correctly as far as I know so I'm at a loss as to why they won't show up.
  • Richard HaseltineRichard Haseltine Posts: 112,037
    Did you install with DIM, Connect or manually? Where are the \Data\DAZ3D\Genesis 3\Male\Morphs\DAZ 3D and \Data\DAZ3D\Genesis 3\Female\Morphs\DAZ 3D folder, and do you have more than one of them?
    I used DAZ Install Manager, never do it manually and still trying to figure out how the hell this connect thing works (bought 1 clothing set that requires it and I still can't figure out where I need to go to install it) I used DIM like I always do, downloaded the files that showed up, then they went into the Installed list. I didn't get any error windows and they installed like usual, but none of them show up in the shaping window. And the Growing Up options (which do appeal) Won't do anything whenever I click them, the figure remains the same as it is.
    OK, could you go to DIM, click the gear icon at top-right, and take a screenshot of the installation tab. Then in DS go to Edit>Preferences (or DAZ Studio>Preferecnes on a Mac), go to the Content Librarty tab, click the Content Directory Manager button, expand Current Set, DAZ Studio Formats, and take a screenshot of that.
  • Hello,
    I got the same issue so I did the screenshot as you asked.
    Please help :)
    1450 x 1569 - 147K
    1655 x 971 - 111K
  • That's the right screen from DS, but from DIM I want to see the paths it is isntalling to - click the gear icon at top-right of your screenshot, next to Help, and then take a screenshot of the Installation tab in that. If you are using the defaults it should be OK.
  • Having same problem witha my G3 morphs that I bought yesterday so hoping issue is solved..note...accoring to my file saving..the morphs at least partially load even if they don't appear because the size of the save file expands..Wondering what I don't have visible that should be visible and what setting it is. I want to use my new morphs!
