no subdivision in Wolf 2.0 by AM
Hello everyone
I purchased the model "Wolf 2.0 by AM"
I saw the model "smoothed" How do I transfer the model to its most basic wire?
  • Richard HaseltineRichard Haseltine Posts: 111,348
    In the Parameters pane go to the Mesh Resolution group and set Resolution Level to Base.
  • I change this basic but does not change the model
    The wire is still a smoothed model
    Are you wanting to see the facets? That is a shading property - open the Surface pane, if it isn't, switch to the Editor tab, and select all surfaces by clicking on the wolf's name in the list, then turn smoothing off in the list of properties.
  • Are you wanting to see the facets? That is a shading property - open the Surface pane, if it isn't, switch to the Editor tab, and select all surfaces by clicking on the wolf's name in the list, then turn smoothing off in the list of properties.
    i want see low poly model...
    Base resolution is as low as it goes - anything further would require mesh reduction or retopology tools (it is a separate purchase, but DS has the Decimator plug-in for mesh reduction though it won't give a clean polygon flow).
