G3M or G2M Clothing that can be "undressed"
i know of some M4 and  few Genesis clothing items that can have undressing or similar morphs (thanks Sickleyield) but I haven't seen others.
Do you guys know of others?
Is there a way to add these morphs to other clothing?
indecision
  • HavosHavos Posts: 5,703
    If you get fit control from Zev0 this adds a number of undressing morphs to any clothing attached to the G2M or G3M figure.
  • BeeMKayBeeMKay Posts: 7,019
    It would depend on the other clothing; often, the clothing is not made for "undressing". With the Sickleyield "Fit" products, you can shove up shirts/pants, and pull them away from a body in a way that looks like you are undressing, but it will not give you the "real thing". To my knowledge, there's no vendor who offers their clothing with an "undress" opption, though Aave Naien has great pose-matiching coming with her clothing.
    http://www.daz3d.com/security-genesis-2-male-s
    and I believe police expansion have this option
  • mtl1mtl1 Posts: 1,508
    Jeanz and Jeanz Skirt are both undressable. Much of Outoftouch's catalog is undressable too.
  • marblemarble Posts: 7,500
    There's "Boyfriend Jeans" at the other store - most comprehensive undress options I've seen so far. But, in general, I agree - while the DAZ human figures may have come a long way in terms of realism, conforming clothing lags way behind. I now avoid buying clothing which doesn't have good morphing options because clothes that don't tend to sit unused in my library.
    I also thought that Aive Naien had the answer but, either I don't have the necessary pose sets or I rarey use pose presets so, again, the Aive Naien clothing is tucked away at the back of the wardobe, hardly ever to be worn.
    If you are looking for a realistic drape, the best option is dynamic clothing. By applying a few tricks during animation, posing the clothes as if undressing is also possible.
    edited April 2016
    Oh, you make that sound so simple! ;)
    How would you unzip a pair of jeans or open a buttoned shirt? It isn't only the drape that's unrealistic, it is the functionality. Zippers and buttons should be possible to open. Some vendors go to the trouble of including such morphs, most don't.
    Edit: Having said that, there are problems with a lot of the undress morphs too. I've noticed that the mesh tends to distort when undress morphs are applied. For example, the loose straps on the Hongyu bikini - lots of dials but it is very difficult to get realism. Often the morphed strings suddenly look about 10 feet long.
    Post edited by marble on
  • Richard HaseltineRichard Haseltine Posts: 111,371
    Part of the problem is that the clothing will still be responding to the posing of the figure at its original location, unless you have morphs tied to specific poses, so there's going to be a limited range of plausible positions. You also have to remember that a morph moves vertices only along a straight line, no curving. If this sort of thing is crucial, and you want to apply it with a range of poses, then using dynamics (or taking the clothes and wearer into an external modeller with its own dynamics and the ability to break the mesh apart) is the only real option.
  • Kev914Kev914 Posts: 1,143
    If you are able to fit M4 and Genesis clothing on to G3M, then DZherg over at Renderoisty has some clothing with undress morphs. I have fitted them to G2M. Not sure I tried G3M, but it should work.
  • JorgexxxJorgexxx Posts: 1
    Zev0 Fit Control for Genesis 3 Male don´t exist..
  • LlynaraLlynara Posts: 4,772
    Sav's Hot Men at Rendo has these options (some of the poses and morphs are pretty hilarious). It's for M4 but you could fit it to G3M with Wear Them All or G2M with the M4 for G2M. Bad Kitteh Co at Rendo has a few outfits like that also, but for M4 as well.
