Boolean searches on Daz?
I'm trying to find a past topic post relating to both geografts and morphs, but the search engine here is returning all mentions of either. How does the search engine here define limited searches? I tried putting in  "geograft AND morph", and "geograft + morph" and get a bazillion useless hits of "morph" all by itself. What is the proper syntax for search requests?
  • lexbairdlexbaird Posts: 168
    edited April 2016
    p.s., the problem I'm encountering is trying to get morphs to work on a geograft I made, without the mesh exploding into spiky random directions.... surely its a problem already solved here, if I could just discover the right post!
    Post edited by lexbaird on
  • Silver DolphinSilver Dolphin Posts: 1,652
    I've found that the search fuction in daz forums is not very good. If you want to find something you need to use an outside search function. Sometimes google works.
  • marblemarble Posts: 7,500
    Try this in google search : site:www.daz3d.com/forums/ geograft morphs
    Anything there?
  • BejaymacBejaymac Posts: 2,002
    You might want to try marble's search but use vertex order instead of geograft morphs.
  • RonSRonS Posts: 299
    Does anyone know why, after all these years, there is still no boolean support in DAZ search?  I'm trying to find out why my Install Manager keeps freezing (not responding) - I've tried all the obvious, like waiting (up to 30 minutes) to see if it responds and sometimes it does, but not always.
  • LeatherGryphonLeatherGryphon Posts: 12,449
    edited May 2016
    I came from the UNIX world and could cast a "Regular Expression" search spell like the wizard I was. devil  Then I found myself dumped into the PC world.  sad Blech, these people have no idea what they're missing. no
    https://en.wikipedia.org/wiki/Regular_expression
  • PA_ThePhilosopherPA_ThePhilosopher Posts: 1,039
    edited May 2016
    I would be curious to know the answer to this as well. The search engine in the store has also been simplified, so it is more difficult now to find certain products....still trying to understand the reasoning behind that move. But I'm sure Daz has a rational explanation for it.
    -P
    Post edited by PA_ThePhilosopher on
