Help Create Collision. Genesis Not Colliding
I used smoothing modifier, collision iteration, interactive update on, pointed what to collide with... The skins still go thru like ghosts. This method succeeded for a prop object and the genesis. But, between two geneses, I can't seem to make collide. Also, please help on making a penetration of a genesis finger, and nose. Is it anything but collision dial? If I have applied to the WHOLE genesis, (assuming I did not mistakenly apply to one PART) what could be wrong
Post edited by Chohole on
That kind of collision usually doesn't work in DAZ Studio. You can use the collision for items worn by the character, like clothing, but you can't collide 2 characters.
You can try using deformers on the surface of the character.
There's an excellent turorial about deformers in one of the DS magazines, but I don't remember whcich issue: http://www.daz3d.com/forums/discussion/61938/ds-creative-the-magazine-for-daz-studio-users
Adding a suit to a body will not solve your problem. You'll end up with your colliding character splattered around the body suit.
The collision in DS just isn't "good enough" to simulate proper physical collision like the one you want to achieve. Like I said, you best bet would be deformers, or create a morph specifically for this action, that you then can dial in as needed.
