question
skeetskeet Posts: 7
Post edited by skeet on
  • Richard HaseltineRichard Haseltine Posts: 112,099
    Make sure you aren't mixing Iray settings on the body with 3Delight on the face, or vice versa. If not then please report it as a possible bug.
  • skeetskeet Posts: 7
    edited July 2016
    Ya
    Which file did you load? Are these renders? It's a little hard to see anythign at that size (for me, at least).
  • fastbike1fastbike1 Posts: 4,085
    I'm not seeing any differences in skin tone. Here are two Iray renders of Sapphire. Both have default Iray HDRI, default Iray render settings, and Sapphire's base Iray skin. Rendered in Studio 4.9.1.30
    530 x 750 - 260K
    530 x 750 - 313K
  • kaotkblisskaotkbliss Posts: 2,918
    I can say they aren't renders. You can see the grid floor behind the model.
    The pre-render load also shows even skin tones across the model.
    edited July 2016
    Ya
  • fixmypcmikefixmypcmike Posts: 19,743
    This is just loading the actor for the figure, or applying the materials to a figure already in the scene?  Are you applying any makeup, etc.?  Are these Iray or 3Delight materials?
    edited July 2016
