SeaFolk KelpBra install failed
As my old purchases from RDNA are coming to DAZ the SeaFolk KelpBra should be installed (ok, it´s already installed in my Poser Runtime). Now the product appears in DIM, downloading without problems but cannot be installed (install failed). What could be the problem?
  • Richard HaseltineRichard Haseltine Posts: 111,908
    Try deleting the zip and redownloading.
  • kaotkblisskaotkbliss Posts: 2,918
    There might be an "&" in one of the file names inside the zip which DIM does not like and will fail on.
  • chrbou2001chrbou2001 Posts: 120
    Six times but nothing changed,it still appears in the downloads and after downloading the "install failed"
    Can you open or look inside the zip manually after it's downloaded? There's an ongoing problem with an unknown number of the RDNA transfers, where the original RDNA zip was built with other zips inside it (a common thing in the Poser-only manual-install-only days of long ago). Maybe this one item is having a similar problem?
    Sorry, no zips inside, meanwhile the second product doesn´t install (Bad Attitude for V4)
    Sorry, no "&" inside.
  • I have the same issue.  I tried deleting the file from the "Ready to Install" tab and re-downloaded it but still fails.  I too didn't see any "&" in the files.  There was a Read Me's folder but don't know if the ' would have any affect on it.
