Help Mesh Parameter Not Showing Up
HarkHark Posts: 48
I applied smoothen Modifier, but there are no dials to control smoothening or collision. The skins on genesis 3s just go thru each other. I have succeeded collision -controlling a prop object. Do characters need a diff option?
  • Richard HaseltineRichard Haseltine Posts: 112,078
    If a Smoothing Modifier is applied to an item the parameter group should be there - make sure you have the figure and not just a bone selected. If that isn't working it's possible you didn't create a Smoothing Modifier, either try again or try removing the one that may not be working (from the Edit>Figure>Geometry menu).
  • HarkHark Posts: 48
    I restarted the Daz, and it showed up. But good tip on selecting whole. After pointed, collision iteration n interactive update is on, human characters still act as if not colliding. Any help on making them collide? I've done it with props...
    I applied the smoothing modifier, pointed who to collide with, bumped up collision iteration to 90, turned interactive update on, and they still act like ghosts. I've made a leg and prop collide with this method. Please lemme make their skins collide. Thank you
  • Cris PalominoCris Palomino Posts: 13,062
    Threads merged as they are on the same topic.
