It's in my runtime, but...
Oso3D
I have a number of objects in libraries in my runtime, pp2.
I... have absolutely no idea where they are in my content DB, and can't search or find them. I can import them, but... what the heck??
Any suggestions?
Edit: Ah, I think they are in the wrong directory structure. Argh.
Post edited by Oso3D on
pp2 are Poser Props, have you looked under Poser formats.
I did, but it wasn't there and wouldn't come up with a search. But the problem was it was one of those 'stuff downloaded with wrong directory structure or I messed up where to put it'
Have you tried the "browse to folder" ?
Did you get them here at DAZ or somewhere else? If you got them at Daz, did you use DIM to install them? For me DIM has always handled poser files without any problem and I've never had to adjust directories or anything - but I don't know how you set things up for your workflow, so that may not be the case for you. If it's a Daz item you can almost always go to the readme and see where in your folders the item can be found. Unless it's one of the new imports from RDNA, because those readmes don't seem to be accessible, at least not that I've found.
