vertical lines in daz 4.5 render
Getting vertical lines in daz 4.5 render using 3d delight
Post edited by DAZ_bfurner on
You can post images to this forum using the Browse button below where you type your message.
This error has been noted by some others, I will see if I can find you a link.
EDIT:
The problem has been discussed here : http://www.daz3d.com/forums/discussion/7910/
See if that helps any?
So currently there is no work around for this
What version of DS 4.5 are uyou using? Go to Help > About DAZ Studio and it will tell you.
If you are using 4.5.0.114, then you it looks like you will need to upgrade to the latest Beta version 4.5.0.137 according to what I read in the thread I linked to.
