How can I find correct path and change it in the install manager ?
When I try to install  "Photoshop 3D Bridge for DAZ Studio 4.9+ (Win 64-bit)"  by Daz install manager in condition " redy to install",
display shows
Install Manager cannot find a required path. The package for "Photoshop 3D Bridge for DAZ Studio 4.9+ (Win 64-bit)" requires that the installed path for "Photoshop CC, CS6, CS5, CS4 (64-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
How can I find correct path and change in the installer ?
  • fixmypcmikefixmypcmike Posts: 19,718
    Click the Gear (settings) icon in the upper right, on the last tab (Applications) click the + sign in the lower left, select Photoshop and add the version, bit-depth and path to the Photoshop application.
  • BeeMKayBeeMKay Posts: 7,019
    blurabito, just to make sure... you want to know how to set the path in DIM, not how you can find the path to Photoshop on your PC/MAC, so you can enter it in DIM?
