Skies of Economy
Does anyone have this?  http://www.daz3d.com/skies-of-economy
SKU:15328
DimensionTheory
DAZ Studio, Poser, Carrara
It clearly says compatible with Daz Studio and when you read the description it sounds like you can use this in Daz Studio without the Reality plug in.  however when I try and load one of the scenes all I get is this message
  The reality toolkit was not found the script will stop exection.
  • I have the same problem with some of his other skies, same message.  How about it DT, any chance of an update?  I do have the latest (4.2) version of reality installed even.
    Did you install both the DS zip and the RealityCF?  The non-Reality versions are in Props/DimensionTheory/SkiesofEconomy while the Reality versions are under Lights.
  • mambanegramambanegra Posts: 601
    Wow! Those promo images look fantastic! This would be a nice addition if it works with Iray.
    Ah that's the problem.  The folder in props was empty.  I went and installed again and now that one works.  Thanks FixmypcMike!  Working just fine now and truly beautiful as well.
