Headlamp Issue
deleted userdeleted user Posts: 1,204
I'm having this issue where in the preview scene, iray renders the way I want. Everything looks good. Bit when I go to render the scene. The headlamp does not render at the same luminosity as the preveiw window. There has been times, where I had to turn the headlamp all the way to 10 to match my pewveiw window. I was wondering if thats normal or not or if I accidentally bumped a setting and didn't notice.
Post edited by deleted user on
    It doesn't really match up, no.  The Headlamp is basically just meant for keeping the preview lit.  you can turn it off and hit CTRL L to keep the scene from going black while you add photometric or mesh lights or turn up your HDR.
  • deleted userdeleted user Posts: 1,204
    This may seem weird but is it possible to have two headlamps? I had an idea.
    Or better yet. Does anyone know the propperties of the headlamp so I can recreate its effects in another part of the room.
  • fastbike1fastbike1 Posts: 4,081
    Just use a photometric spotlight. Change the parameters for the effect you want.
  • nicsttnicstt Posts: 11,715
    Turn the headlamp off; imo, always make sure it's off.
    There's a Headlamp on every camera in your scene. This is separate from the Preview light (which doesn't render) that you turn on and off using <ctrl>-L.
    As for the Headlamp properties, remember it's a camera function, not an actual light; look at the parameters for your camera.
    But sometimes the headlamp light is the lighting type I'm looking for. Thats why I wanted to know how to get two of them.
