Can't see Dragon 3
In poser 11 nor poser pro 2012. Have reloaded Dragon 3 and attempted to load the character in both apps but have no joy seeing it. the hierarchy editor shows it present but have no visual on the screen. On a Mac with latest OS. Works fine inDAZ studio. What am I missing?
  • cclesuecclesue Posts: 420
    I can't see Dragon three in either Poser 11 or Poser Pro 2012 while it shows up just fine in DS. Poser I down loaded Dragon three and reloaded to be sure all files are where they should be. Thinking I'm missing something simple. . . D3 shows up as present in the Hierarchy editor but can't see in preview window. Tried to apply texture. . . no joy. What am I missing?  The files i downloaded from DAZ does not include Geomentry files do I need them?
    On a Mac latest OS.
  • Richard HaseltineRichard Haseltine Posts: 111,332
    You did install both the DSON Core and the PoserCF packs?
    Dson Importer?
    Merged threads.
    Did you install both zips (the main zip and the PoserCF?)
    I manually installed all files exactly as they came out of the zipped unstuff. I never can understand the Dson business but all my other genesis stuff that I've tried in poser seems to work. do I have to install Dson with each new character? Where would I look to see if it is installed correctly? Is it not a python script?
    You don't need to install the DSON Importer more than once.  What is the full path to ...\data\DAZ 3D\DAZ Dragon 3\Base\dragon.dsf?
    Not sure what you are requesting here but this is the full path:
    1206 x 552 - 210K
    Is the Runtime in "My DAZ 3D Library" listed in Poser?
    Listed in poser? not sure what you mean. I placed all the files manually to exactly where they are indicated to go in each of the file packages CF to poser runtime and the other to My DAZ 3d Library is that runtime supposed to be listed in poser if so where?
    In the Poser library add that location as a runtime, otherwise Poser won't be able to find them.
    Okay now I see the dragon but still can't do anything with it. Poses don't work correctly. Using MyDaz library or using poser pro library.
