Why does 'Work Offline' take ~10 minutes to activate?
Greetings,
So I bought some items in the store; they weren't showing up under 'Available' when I went into the store mode, so I figured I'd make it refresh by clicking 'Work offline', then logging in again.  It took a solid 10 minutes before the UI returned to usable, and replaced 'Work offline' with the green 'Login...' button.
I remembered that I'd had a similar problem earlier today, when I needed to pause the downloads so I could have a video call with work, so I clicked 'Work offline', but I hadn't paid attention to how long it took that first time.  (Btw, is there ANY other way to pause downloads?)
So...why is it taking so long to do what _should_ be a simple operation?
--  Morgan
  • nicsttnicstt Posts: 11,715
    Is there a log to check?
    Mine takes about 6 seconds; I have 1700 installed products (via DIM) - have removed all Poser parts that are not required.
  • Richard HaseltineRichard Haseltine Posts: 111,805
    CypherFOX said:
    Greetings,
    --  Morgan
    Cancelling is the same as pausing, more or less, since it should quickly verify the files it had downloaded and move on to those it hadn't when you restart - but no, there isn't, as far as I know, a way to explicitly pause.
