Id renders in daz studio? Can it be done?
Hello eveybody..i wanted to ask if you know a way to have  material id or even object id in daz studio...it helps a lot picking specific parts for compositing in photoshop....thanks everybody in advance....
  • Richard HaseltineRichard Haseltine Posts: 111,842
    You can using the canvasses featuer with Iray - enabled and managed in the Advanced tab of Render Settings, Material ID is one of the layer types.
  • Cris PalominoCris Palomino Posts: 13,030
    If you have more than one mesh in the scene you are rendering, you can create a node and press the "..." next to the node line for a list of the objects.  Select which mesh for which node.
  • ISIKOLISIKOL Posts: 386
    Thank you so much Richard
    Thank you Chris..can you please explain the procedure further? Im new to studio and i dont know how to create a node....and where...
    another question is (sorry i didnt want to open a new thread for it) can i have a selection render but in the normal dimensions of my current camera? i have find the selective render tool but it renders directly to the screen and without any option to save....
    http://prntscr.com/as1phd  and  http://prnt.sc/as1rzn  should explain.  :)
    Do you mean spot render?  http://prntscr.com/as1tnf  Enable Spot Render with the first icon and then Tool settings (icon the arrow points to) and set to render to new window.  The render will be the size of the full render with only the region you lasso with the spot render tool will be rendered.
  • MN-150374MN-150374 Posts: 923
    For 3Delight Renders there is this Script by DraagonStorm: http://www.daz3d.com/mask-and-multipass-toolbox
    Not sure if it will work with Iray, but it is perfect in 3Delight.
