Is there a current thread about Connect products where questions can be asked?
jakibluejakiblue Posts: 7,281
Questions such as, why are the older Michael 3 and the Victoria 3 base connect ready and can be downloaded via Connect, when the Michael 4 Base and his morphs++, and the Victoria 4.2 Base and her morphs++ are not connect ready at all? Even tho LOTS of M4 and V4 characters that require these bases and morphs are currently Connect ready to be downloaded within DS?
    It all has to do with the EXPmorphs and the way M4 and V4 need to be 'initialized'...Connect can't run the script.
    The generation 4's ExP morph system requires that all figures and morph sets be installed to the same library.  Connects install each product to its own sub-library folder within the larger Connect library folder.
    AH! thank you mjc & jestmart.
    Hmmm does that mean i have to manually install them and create the metadata? Can I do the "manual connect install" or does it have to be normal manual install?
  • fixmypcmikefixmypcmike Posts: 19,718
    Manual or DIM, the Offline Connect won't work.
    Thanks Mike. :)
