Iray Converter for Generation 4 not via Connect? *solved*
jakibluejakiblue Posts: 7,281
edited April 2016 in The Commons
Before I go opening up a ticket for this, I want to check that I'm not just going blind and/or insane (always a possibility).
I purchased the Iray Converter for Generation 4 and can't seem to locate it in Smart Content to download via Connect.
I've checked in "All" and in "Available" and also "Installed"
I've done a search on its name by copying and pasting the title from the store - and while I get about 600 returns (go figure) none of them are correct.
I"ve made sure I have "filter by context" unselected.
The "Iray Smart Converter and Advanced Skin Managers for Genesis 2" that I also purchased, are showing up in available as normal, so I can't work out WHY the one for generation 4 isn't showing ANYWHERE for me to download. (Yes, I've checked "installed" in case I had already d/led it and forgotten)
Can anyone else who owns this check to see if it's showing for you?
Post edited by jakiblue on
  • LindseyLindsey Posts: 2,012
    edited April 2016
    I'll typically search by the full product name in quotes.  See pic attached.
    Sometimes when searching by the full product name doesn't work, I go to the Product Library.  If it's there, select it, right click and "Show in Smart Content".
    575 x 490 - 118K
    Post edited by Lindsey on
    DAMN.
    It's there.
    That is so bizarre. I had searched with the full name, but NOT in quotes. I tried Iray, Iray converter, generation 4, ....and not once did it show up. And now, hey presto, addition of quotes and it's there. :sigh:
    Thank you for that. I was getting really frustrated.
    Um.....where are they located in Smart content? I thought "scripts" but then, Scripts doesn't even show up on the left when I have "installed" selected.
    Ah. Finally found them - under "Materials". Sheesh.
