4.9 Has Turned Grindingly Slow
thomvinsonthomvinson Posts: 79
Getting "Duplicate Formulas" errors and everything is taking forever to load. I have created some morphs recently, but if anything they have only compounded an existing growing problem. To make things even worse, I attempted to delete a morph and started getting "Missing Formula" errors, putting it back stopped that problem, but I am still facing the original issue. Daz 4.9 is turning into glacial mud. Rebooting hasn't helped and I really don't want to re-install and have to set everything back up yet again.
How do I safely delete unwanted morphs?
What could be slowing it down?
How do I speed up my badly lagging and much loved Daz Studio?
Post edited by thomvinson on
  • Richard HaseltineRichard Haseltine Posts: 111,459
    Have you checked the log file (Help>Troubleshooting>View Log) to see exactly which morphs or properties are throwing the Duplicate Formula errors?
  • Yes I have, there are about 8 unique files, each one in about 40 folders and one in a jillion folders. *sigh* I have been deleteing stuff all day, and of course that results in "Missing Forumla" errors, not sure which is worse, but things are speeding up a bit.
    alias_Genesis3Female_XID_Genesis3Male.dsf popped up in every folder in the /Data/Daz 3D/genesis 3/female/Morphs/*/*  path.
    I have to admitt being confused why it caused an issue, there are hundreds of files with the same names in various folders on the same path that do not cause errors. . .
    I think the one you name is the Cross Figure tool for G3F.
  • thomvinsonthomvinson Posts: 79
    edited April 2016
    Not getting anymore Duplicate Formulas errors so that worked.
    But how do I safely delete unwanted Morphs? I cannot seem to find a method that doesn't result in Missing Formula errors. And the ones I tried to just flat delete still show up on the morphs list, and produce the "Missing Formula" when Daz is loading a figure.
    It would be better to figure out just which sets are causing the errors so that they can be fixed.
  • True enough, it would be great to be able to fix them. But I am still left with unwanted morphs that take up time loading, I would like to be able to safely remove them.
    Removing unused morphs by uninstalling the package or by deleting the files in the Data\Publisher\product\Figure\Morphs\Morph creator\Morph set folder should work.
