Redacted
cridgitcridgit Posts: 1,765
edited December 2022 in Daz Studio Discussion
Redacted
Post edited by cridgit on
  • niccipbniccipb Posts: 483
    Hi cridget...
    For whatever reason it looks like you still have the .dsf templates in the template folder along with the templates for 4.5 which are in .duf format.
    Go to data/DAZ 3D/Genesis/Base/Projection Templates and check each folder for .dsf files.
    Just remove the .dsf templates and that will get rid of the double listings and you won't end up picking the old templates in AutoFit.
    Hope this helps... :)
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
  • barbultbarbult Posts: 27,655
    FWIW: I have only Knee Length.duf in my dress folder. I don't have any .dsf files at all in the Projection Templates subfolders.
    Hi cridget...
    Your very welcome...
    Dress/Knee Length.duf is tight to the figure and replaces Dress/Tight.dsf
    Ya it's seems like the old templates didn't uninstall for you like they should have.
    Here's what you should have...
    Bodysuit /Loose.duf
    /Tight.duf
    Boots /BootsThigh.duf
    Dress /Knee Length.duf
    Gloves /Tight.duf
    Hair /Long.duf
    /Short.duf
    Pants /Loose.duf
    /Tight.duf
    Shirt /Tight.duf
    Skirt /Knee Length.duf
    nicci... :)
    edited September 2012
    your case is same what I found .
    So I deleted dsf temlplates in data.
    and some of template must make wrong face grouping about some node,
    in ds 4.5 .0. 114
    so if you posing the node ,there will be poke through or unusuall shrinking.
    I checked and confirmed about , bodysuits , gloves, and shut template.
    (and "dress type" too, if you rotate r-coller, you may find the problem)
    developer said, this problem have been removed in next ver of ds 4.5
    so untill it will rerease, I recommend use auto-fit with type "none",
    and use transfer utility with no projection template.
    they seems work well.
    Post edited by kitakoredaz on
