Can't Find Iray Uber Shaders
I'm finally taking the Iray plunge. All the tutorials I've watched today refer to the Iray Uber Shader, which apparently I don't have. I have DAZ Studio 4.8 Pro (4.8.0.59) 64 bit. The tutorials were all made using the old public build version, so have the shaders been moved from Shader Presets? Or are they an addon package now?
    Did you install all the default packages...the various Starter Essentials, the lights/shader packages?
  • NathanomirNathanomir Posts: 133
    I thought I did. I did a clean reinstall today, to make sure, but I may have missed something. Good idea to check those.
    Best as I can tell, everything was installed. The photometric light shows up for spotlights when Iray is chosen as the rendering engine.
  • fixmypcmikefixmypcmike Posts: 19,742
    Did you install "Default Lights and Shaders for Daz Studio"?  (It was updated for DS4.9 and is now called "Default Resources for DS4.9", but if you're using 4.8 you're better off using the old version.)
    Geez. Looks like I'm screwed. I just spent an hour searching through my saved downloads, and Default Lights and Shaders isn't there. I probably didn't think it was necessary to get when I upgraded from 4.6 to 4.8. Well, thanks. At least I know what the problem is.
    And as soon as I posted the above, I found it. That took care of it. Thanks!
