Upgrded to 4.9 ... can't find stuff!
in New Users
I'm using the skeleton anatomy pack. I'd like to change the colors of some of the bones, but not all. I was able to do this before, but it seems I'm unable to now? Before, if memory serves, I'd select the bone in question from the node window (where I could make it appear/disappear as well) Now It seems I have to select the whole arm from the Shading wondow. Is there a work-around? I've got an article in a magazine I'm trying to make an image for...
Second, the eyes won't disappear anymore! I can toggle them in the Node window, but nothing changes. Everything else seems to appear/disappear as normal, but the eyes are stuck there. Anything I can do to make them go away?
Thanks!!!
Generally one would use the surface selection tool to change colours or make invisible selected parts if the individual parts' visibility can't be turned off as a subset in the scene tab.
You would select the bone with the surface selection tool and reduce to zero its opacity strength to make it invisible, or change the colour as needed with the same tool.
Thanks for the tip. I can't seem to be able to select the bone... only the skin region on the Michael 4 muscles maps. I think I'll just render it at photoshop it.
I still can't get the eyes to turn off, either :
