Recategorize a morph to a posing menu?
in The Commons
Morphs like expressions and some pose correction morphs have a separate "Posing" tab where they appear and then are easy to find and zero when you want to move to next pose.
Issue is there are some morphs that I want to use in poses only but they are not categorized as such as only show in params.
Is there a way to permanently add category to existing morphs so they would also show in "Posing" tab in all scenes? I can edit them in scene and make them a pose morph but it wont be carried to new scenes.
Make the change in Parameter Settings, save that as a character or persona preset, and use that to load the figure - does that work?
The problem is this will only afect that figure. I want this to ideally recategorize the morps globally so each figure can use them.
So you have a morph that is, let's say, under /Actor/Head and you want to have that morph visible in the Posing tab, which seems to require for that morph to be also under /Pose Controls/ ?
Maybe an alias could do it:
https://www.daz3d.com/forums/discussion/484986/how-to-create-an-alias-of-a-property
That was going to be my next suggestion, yes.
