Render silently to file
There is a way to render directly to file without any render window popping up?
    edited October 18
    In the Render Settings Editor tab in the General section, you can change the render target to File and enter the image name. When you start the render, a progress window will pop up, but no image render window will be displayed. I don't know if the progress window can be suppressed.
    610 x 644 - 79K
    600 x 645 - 87K
    Post edited by barbult on
  • Thank you @barbuit. I'll check if the SDK allows to do that with code.
  • V3DigitimesV3Digitimes Posts: 3,502
    If I remember well even scripts do that, I would be astonished if plugins could not.
    Yep, it does work indeed.
