How to Improve Render Quality with an 8GB GPU
Hey everyone!
Does anyone here have experience with getting the best possible render quality in DAZ when you only have an 8GB GPU?
Unfortunately, with prices being so high right now, I can’t afford to buy a better GPU, but I’m definitely planning to upgrade at some point. For now, though, I have to make do with my RTX 4060.
I don’t want to give up my hobby because of this, but I find it really difficult to get beautiful, sharp, detailed renders. I usually turn on the denoiser very early, but unfortunately, the final image ends up looking kind of mushy. This seems to happen no matter when I turn it on, even if I wait until after 2,000 iterations. I always set the max samples quite high, too.
However, if I leave the denoiser off completely, rendering takes twice as long, and I still end up with too much noise.
I already try to keep my scenes as minimal as possible to save VRAM, but I still can’t seem to achieve renders that look as realistic as those of so many other artists.
Does anyone have any tips or perhaps some render settings I could try?
  • MasterstrokeMasterstroke Posts: 2,522
    edited October 16
    Difficult.
    Keep your scene most sparse.
    Look for a camera clipping tool. ( hides everything outside the camera's field of view. You can choose, if lights are clipped as well)
    Consider to render in passes. (Forefround, middleground and background)
    There is a tool called Scene Optimizer here in the store. It can reduce texture sizes in a scene and saves it in your texture folder without overwriting.
    Right now I am working on a project, that includes lots of renders.
    In order to manage that, I render at low resulution by 1600 X 900 pxls.
    I use the latest Paint shop Pro in order to upscale the render results with AI support. Yes, AI, but NOT generative AI.
    Hope that helps :)
    Post edited by Masterstroke on
  • jmucchiellojmucchiello Posts: 2,620
    edited October 16
    The real question is how strong is the rest of the computer. The normal answer to your problem is lots of beauty canvases. But if your computer can't handle a big scene, canvases don't help.
    But ultimately rendering in pieces and assembling externally is probably the way to go.
    Post edited by jmucchiello on
  • FishtalesFishtales Posts: 6,238
    It could be just your settings. I have an RTX 4050 with 6GB and my images look noise free and sharp, to me anyway :)
  • Masterstroke said:
    Difficult.
    Hope that helps :)
    Well, that doesn’t really help me with my problem. I’ve been using the Scene Optimizer from the very beginning. I always reduce everything to 2K. I can render just fine. It’s not like my renders always crash or anything. I’ve even managed to render scenes with multiple characters.
    My only concern is that the final image doesn’t look like mush, but actually shows skin details, such as pores, for example, and that the skin doesn’t look like plastic. That’s mainly why I was asking about render settings. Maybe I’ve got something set up incorrectly in terms of what my GPU can handle.
    I’ve also specifically switched to small vignette scenes or 2D backgrounds, where I build a little scene myself using a few props. I do all of this to keep the focus on the character so that at least the character itself has good quality. But I just can’t seem to get it right.
    I’m aware that my GPU can’t work miracles, but surely it should still be possible to retain at least some degree of realism in the characters.
    I just feel like I have to rely on the denoiser because otherwise I can never get rid of the noise, no matter how long I let the render run. But how do you set it up correctly? Or maybe I’ve got the render quality settings wrong. Do you even need to change those? I’ve always left them on the default settings.
    I’ve always used Mitchell for the pixel filter and set the radius to 1.0, sometimes even lower. I have no idea whether that actually makes any difference to the problem I’m having.
    That’s why I’d really like to know what settings other people use if they also don’t have an especially powerful GPU but have somehow managed to keep their characters looking realistic.
    Could you maybe share your render settings with me, then? That would be really helpful! smiley
    Well, my renders otherwise work fine without crashing or anything. They just usually take an hour or even longer. So I assume the rest of my hardware is adequate, at least for my PC, which isn’t exactly new anymore. As I said, I’m planning to upgrade at some point anyway, but that’s just not possible right now.
    I’m still happy to list my hardware, though:
    CPU: AMD Ryzen 7 5700X
    RAM: 32GB
    GPU: RTX 4060 with 8GB VRAM
    OS: Windows 11
    It really is just the quality of my characters’ skin that bothers me. It always looks so blurry and mushy. I never see any skin details, like pores or anything else.
    And no, I don’t really touch the surface settings to change anything. I load the characters into the scene as they are. The only thing I use is the Scene Optimizer to reduce textures to 2K so my graphics card doesn’t crash when I work with larger scenes containing multiple characters.
    I just don’t understand what I’m doing wrong. Other people manage to get it right, too...
  • kprkpr Posts: 505
    edited October 17
    RAM: 32GB
    OS: Windows 11
    I have a v similar rig.
    I can do these (30mins and 60mins render time):
    https://www.daz3d.com/gallery/user/5444756578500608#gallery=newest&page=1&sort=trending&image=1351734  :
    https://www.daz3d.com/gallery/user/5444756578500608#gallery=newest&page=1&sort=trending&image=1349453
    NB: That is Viki 8k, so there's a heap of skin-detail. Do you have an 8k skin to check? The other image uses a custom SkinBuilder Skin (G8).
    FWIW: some characters only reveal detail in SubD3 and greater, so check that. And if you are using SceneOpto on the characters, then that will be the problem.
    For a simple scene - like Viki and the bow and arrow - you shouldn't have problems pulling lots of sharp detail.My settings are pretty much vanilla, I don't use the denoiser etc.
    Try attaching a render - or gallery link - you've done so we can see what you mean
    Post edited by kpr on
  • garrett_3dgarrett_3d Posts: 1,056
    The machine I'm on now isn't massively different spec to yours. Ryzen 5 3600, 32GB DDR4 3200MHz, RTX 3080Ti, W11. I originally built it some years ago with a 4060 before upgrading and the system has been tweaked a little to improve performance.
    I had similar issues with "fuzziness" as I call it. After some trial and error, plus a few hints from friends and on here, I found that playing with scene lighting made a huge difference. Also, I tend to only start denoiser after 2000 iterations and tend to use it only in low light scenes. I also have auto headlamp switched off permanently.
    The attached render was done on the 4060 in 4k resolution without denoiser. It took about 5 hours. Not the best G8 character, I think the base character I used was a fairly old asset. I'm not too sure what went on with her forehead either, it looks like she's growing hair out of it.
    1800 x 1013 - 741K
    RAM: 32GB
    OS: Windows 11
    https://www.daz3d.com/gallery/user/5444756578500608#gallery=newest&page=1&sort=trending&image=1351734 ; :
    Unfortunately, I can’t open the first link, and as for the second one, yes, you can see some nice details there. You can really achieve that in 30–60 minutes?
    I admit that I’ve usually applied the Scene Optimizer to the characters as well, because whenever I had one with 8K textures, my GPU would immediately give up if I also loaded an environment. I’d just get a black image, and the render would stop instantly.
    Not every character I own has 8K textures. Most use 4K textures and are game models rather than original DAZ characters. However, the last character I bought definitely has high-resolution 8K textures, and I’ve also seen renders by other artists using this character where you can actually see the skin details. With mine, though, all I get is mush.
    I’ll try attaching an image, the last one I rendered using this exact character. There are no details to speak of, and this is what my renders usually look like when they’re finished.
    As I said, I’ve also tried leaving the denoiser off, but then all that’s left at the end is noise, which looks just as bad. I’ll try following your advice, though. I’m just worried that my GPU will crash again...
    1011 x 918 - 993K
    That doesn't look too bad to me. What character is she? If she's G8, I more than likely have her so can run a render through for comparison.
    The top looks a little plasticy so maybe change the textures? Also, does the it have dForce? It looks a little odd having it clinging to the midriff, it should be hanging a little on her left side.
    Have you tried adding DoF? That will reduce the VRAM usage quite a bit.
    I have attached my default scene that loads with DAZ Studio and it has all my startup settings. I do change a couple of things depending on the scene mostly environment brightness, Dome rotation and Crush Blacks.
    duf
    duf
    _default-scene.duf
    14K
    Yes, it’s a G8 character. And no, the clothing doesn’t have dForce, and I haven’t added it either. I’m still not really familiar with how that works, so when something like that bothers me, I’d rather use clothing that already comes with dForce.
    I’ve actually given up on this render and haven’t finished it because I’m already unhappy with the character’s skin. As I said, the character actually comes with good textures, but I can’t see any skin details.
    Maybe I’m also using DoF incorrectly and simply having too much of the character outside the focus area, which would make it look slightly blurry as well. But honestly, I find that hard to believe. I mean, even the face isn’t sharp or realistic, and that was in focus.
    I’ll just keep experimenting. Maybe I’ll eventually manage to make my renders look better.
    Thank you! I’ll give it a try with these settings.
  • nonesuch00nonesuch00 Posts: 18,897
    I would
    a) Render at 720P
    b) Upscale to FHD or 2K using DLSS with an app designed to use your RTX 4060 8GB GPU to do specifically that
  • kprkpr Posts: 505
    edited October 17
    (I corrected the 1st link in my original post, if you'd like to take a look at an 8k figure)
    (Yes, took just over an hour for the second render)
    Thanks for attaching your image, it's not too shabby at all; your lighting is very good smiley
    Some things you might try:
    • If it's G8 then I'd be surprised to read it has 8k textures. You might try one of the newer D+ Colin Jackson characters... $5 or so if you hunt around the sale... that are specifically advertised/named with 8k skins
    • You might try closer renders; a full figure requires much more pronouced detailing in the textures to be seen at that distance
    • Your GPU won't crash... You just won't get a render started if you exceed the 8GB limit with a scene (no harm gets done)
      • Your 8gb card will easily handle the scene you've demoed - it would handle at least two characters in a scene like that
        • If it won't, do you have multiple monitors connected (for the rendering, unplug them if you do); are you running any other apps while you render (don't if you are). If I think it's going to take more than an hour, then I let the render run overnight, pushing your card to its limit is fine but it does mean "waiting a while"
    • A couple for comparison
      • https://www.daz3d.com/gallery/#gallery=all&sort=popular&page=1&image=1307915 <-- (not one of mine. A gallery random). I think your attachment compares very well but check the effects used in the first image compared to the 2nd the kind member has added. The 2nd is the original and is very well lit - There are plenty of advanced "courses" on Youtube that might reveal some tricks (there are a few used in that example); but importantly there is a lot of postwork done on the first image (there are many youtubes on that area too)
      • https://www.daz3d.com/gallery/user/5444756578500608#gallery=newest&page=1&image=1352845 <-- just a couple of MB under my card's capacity. One render pass. Much use of Scene Optimizer and a lot of lighting "tricks". If you zoom, take a look at the dwarf (it is 8k). My log says over four hours to render
        •  You could render scenes like that in a couple of stages. There are Youtubes on how to carve up a scene to do that
    • Canvases: You might want to search for some youtubes on the use of those; great postwork makes a lot of difference (see the not-my-gallery example)
      • DLSS - mentioned by @nonesuch00 - is advanced postwork, if you can find an app you like (and can afford etc) it is well worth it if "pro" is what you are looking for
    Your attachment shows you can render well... IME, learning/practicing what some folk on here call the pro-tricks takes longer still (I still am!)
    smiley
  • prixatprixat Posts: 1,630
    It looks like the denoiser is removing the skin details you're looking for!
    Is the detailed skin visible in the renders that you consider noisy?
