BJ Content History Plugin Help Please
I just purchased BJ Content History Plugin. There wasn't any indication that it required any other products, but I can't figure out how to activate viewing it. Any help would be greatly appreciated.
  • ElorElor Posts: 4,214
    I don't have it (it's a Windows only plugin as far as I can see) but you can check that this plugin was correctly installed by going to Help > About Installed Plugins
    If it is, it should be visible in the list of plugins with a green icon.
    If and once it's active and installed, you should be able to see in the Window menu, then the Panes (Tabs) submenu.
    If you're opening it through this menu, you can dock it by clicking on its tab and dragging it to were you want to dock it.
    You can also directly right click outside a tab in one of the various panels with tabs you likely already have and select Add Pane to Group, which will directly open the plugin panel and dock it.
  • Thanks for the assistance. It worked just like you listed.
  • 3DSaga3DSaga Posts: 945
    Does it run on DS 4.24? I installed it using DIM and it shows it as installed. I don't see it in the list of installed plug-ins nor do I see it under the list of panes.
  • Richard HaseltineRichard Haseltine Posts: 111,842
    Contains the plugin for both Daz Studio 4 and 6.
    and it is there for me. Make sure it is the DS 4.5 version you ar elooking at in DIM, not the DS 6.
    Thanks, Richard, I double checked and made sure DIM installed the 4.5 version. This has got to be the result of me overlooking something obvious. This wouldn't require some sort of separate registration, would it?
    I was right in that I was overlooking something obvous- I needed to restart DAZ!  Now it appears in the list of installed plug-ins.
    Ah, sorry - I should have thought to check you'd done that.
    No problem, Richard!
    Another queston, these are just links to assets that have been used, right?
