Aux Viewport problem
LD1LD1 Posts: 189
edited September 21 in Daz Studio Discussion
I don’t know what I did, but my Aux Viewport used to stay visible at the top right of the DAZ window (just like with the City Limits light workspace). I could then click on other tabs on that side to access them. All the while the Aux Viewport remained viewable.
Well now the Aux Viewport is part of the same group as the rest. So I either see it expanded down the right side or one of the other tabs. Never both at once.
I have tried dragging the Aux Viewport off and then back. It just joins the group of other tabs. How to I get it to (I guess) be a group unto itself so it stays visible while I click on other tabs?
Help!
Post edited by LD1 on
  • NorthOf45NorthOf45 Posts: 5,916
    Sounds like you have moved the Aux Viewport to the other pane group. Normally it would be in a second pane group (upper right). If you drag the Aux viewport tab out of its pane group nad drop it on its own (away from any other panes), it will make its own little pane group. You should then be able to dock that pane group, then it will stay separate from the others. If it does not dock on the proper place, you can drag and drop that group where you want. A highlighted bar will appear when you are in a valid position to dock it.
  • LD1LD1 Posts: 189
    Thank you! I had been trying to drag it to where the (vertically aligned) tabs were. This only added it to the current group. I completely forgot about dragging it above a group to add a separate group.
    It works! Thanks Northof45!
    yes
