Mixamo Animations Import
csteell_c2893e4ab6csteell_c2893e4ab6 Posts: 542
edited September 2 in Daz Studio Discussion
Has anyone used the free Genesis 9 Mixamo animation import tool? I have followed the instructions to the letter and I cannot seem to import any animations into DAZ Studio 6! In the instructions it says it is supposed to work with both DAZ Studion 6 and 4.24! Cheers
Post edited by csteell_c2893e4ab6 on
  • brainmuffinbrainmuffin Posts: 1,332
    Which one? I've used this one in 4, haven't tried 6 yet.
    https://www.daz3d.com/mixamo-rigged-genesis-9-character
  • csteell_c2893e4ab6csteell_c2893e4ab6 Posts: 542
    edited September 5
    This is the problem I have! This banner comes up! I tick import animation and all I get is figure with bones, no animation! Any help appreciated. It is DAZ Studio 4.24 using DAZ's Mixamo import for Genesis 9. Cheers
    691 x 931 - 120K
    2332 x 1394 - 255K
    I'm having that same problem with version 6, but I can import into 4 and save the pose as a workaround. The saved file loads in 6.
  • I wonder if the problem is I am using Premier DAZ Studio 4.24? Cheers
    Are you using the same rigged character that I am? The one in the link I posted.
  • Yes! It is DAZ's Mixamo Rigged Genesis 9 Character I have purchaesed. Cheers.
  • I tried again today! It does not work for me! Can anyone suggest what I may be doing wrong? Cheers
  • CES3DCES3D Posts: 256
    I noticed a couple of details in your screenshots that might help you fix this.
    First, according to the manual for the Mixamo Rigged Genesis 9 Character, the drop-down menu in the FBX Import Options dialog should be set to "mixamo.com". However, your screenshot shows "animation" selected. Changing this to the correct profile might solve the issue.
    Second, if you follow the manual correctly, the geometry of the FBX file imported in Step 7 should be the Mixamo Rigged Genesis 9 character, not the Genesis 9 Base. It might be worth double-checking the instructions carefully to make sure no steps were skipped. I hope this helps!
    501 x 619 - 96K
    1280 x 1158 - 322K
  • Finally got it to work in both DAZ Sudio 4.24 and Studio 6. Many thanks everyone for your replies.It took some time reading and condensing all the instructions. Cheers
